Importing Sketches
Marcistat
6
I have a particular sketch (logo) that i use quite often. Is there a way to import it from part to part? Also, will this allow me to re-size it for smaller uses?
This particular problem involves wrapping the logo onto different cups, and i want to make sure all the logos are the same.
Thank you
We just had a presentation at the NISWUG meeting on this. As long as you don't have to scale differently in X and Y a block is just the thing. You can use blocks in the wrap feature. I consider blocks as presolved sketches so applying the sketch as a block may save rebuild time for you.
You can also save your blocks to the design library to provide drag N drop capability.
TOP
CSWP, BSSE
"Node news is good news."
