Importing AutoCAD2000 drawings to ABAQUS
MNS747
Aerospace
GB
Hi all,
Is it possible to import an AutoCad 2000 solids drawing into ABAQUS for FEA analysis. If it is possible then how to import from Autocad or how to export through autocad to Abaqus?
I would be gratefull if I get any answers to this.
Your best bet would be to export a SAT file (ACIS) from AutoCAD. This will import very nicely into ABAQUS/CAE (since it uses ACIS as the geometry engine).
If you can't export SAT then try STEP...
If it's a 3D solid file, then as brep says, .SAT is the way to go. Failing that, try .STEP.
If it is 2D geometry, you can import it as sketch geometry in CAE via a .DXF file.
Martin
Thankyou very much for your replies and kind assisstance to me.I am much obliged and try this. If get any querry I'll again bother you all.
