Import parasolid journal
rafl
41
I've recorded a program that imports parasolids from a specific folder. Is it possible to add current date as a name to imported bodies names in part navigator
I think this will do what you want. You may need to edit the format string to get exactly what you want.
Code:
[COLOR=blue]Imports[/color] System
[COLOR=blue]Imports[/color] System.IO
[COLOR=blue]Imports[/color] System.Windows.Forms
[COLOR=blue]Imports[/color] NXOpen
[COLOR=blue]Module[/color] Import
    [COLOR=blue]Sub[/color] Main
		Dim theSession [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
		Dim workPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Work
		Dim myFeatures() [COLOR=blue]as[/color] Features.Feature [COLOR=blue]=[/color] workPart.Features.GetFeatures
		Dim lastTimeStamp [COLOR=blue]as integer =[/color] myFeatures(myFeatures.Length-1).Timestamp
		Dim time [COLOR=blue]As[/color] DateTime [COLOR=blue]=[/color] DateTime.Now
		Dim format [COLOR=blue]As String =[/color] "yyyyMMdd"
		Dim displayPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Display
        [COLOR=blue]Try[/color]
           [COLOR=blue]Dim[/color] openFileDialog1 [COLOR=blue]As New[/color] OpenFileDialog()
            openFileDialog1.Filter [COLOR=blue]=[/color] "Parasolid files (*.x_t)|*.x_t|All files (*.*)|*.*"
            openFileDialog1.FilterIndex [COLOR=blue]=[/color] 1
            openFileDialog1.RestoreDirectory [COLOR=blue]= True[/color]
			openFileDialog1.InitialDirectory [COLOR=blue]=[/color] "D:\Parasolid"
            [COLOR=blue]If[/color] openFileDialog1.ShowDialog() [COLOR=blue]=[/color] DialogResult.OK [COLOR=blue]Then[/color]
                 Console.WriteLine(openFileDialog1.FileName)
                [COLOR=blue]Dim[/color] sr [COLOR=blue]=[/color] openFileDialog1.FileName
				Dim importer1 [COLOR=blue]As[/color] Importer
				importer1 [COLOR=blue]=[/color] workPart.ImportManager.CreateParasolidImporter()
				importer1.FileName [COLOR=blue]=[/color] sr
				Dim nXObject1 [COLOR=blue]As[/color] NXObject
				nXObject1 [COLOR=blue]=[/color] importer1.Commit()
				For [COLOR=blue]each[/color] feat [COLOR=blue]as[/color] Features.Feature [COLOR=blue]in[/color] workPart.Features
					if feat.Timestamp > lastTimeStamp [COLOR=blue]then[/color]
						feat.SetName(time.ToString(format))
					end [COLOR=blue]if[/color]
				Next
            End [COLOR=blue]If[/color]
        [COLOR=blue]Finally[/color]
        End [COLOR=blue]Try[/color]
    End [COLOR=blue]Sub[/color]
End [COLOR=blue]Module[/color]
www.nxjournaling.com
I'm getting an error in line
Code:
Dim lastTimeStamp as integer = myFeatures(myFeatures.Length-1).Timestamp
if the file doesn't contain any model history. When there's an object in model history every thing works great.
Try this one:
Code:
		Dim lastTimeStamp [COLOR=blue]as integer =[/color] -1
		if myFeatures.Length > 0 [COLOR=blue]then[/color]
			lastTimeStamp [COLOR=blue]=[/color] myFeatures(myFeatures.Length-1).Timestamp
				importer1.Destroy()
				Next
Everything works great, Thanks again Cowski
