Onno
- Jul 15, 2002
- 49
I have a question regarding the so called "black body cavity".
I am working with small Molybdenum cups (height 6 mm; d = 4 mm; bottom thickness 2mm; wall thickness 0.2 mm) A set of stainless steel radiation shields (3) is mounted around the cup in its vertical direction. The cup top opening is shielded with 2 thin stainless steel plates with a 1 mm hole in it. The bottom is open and is heated by a 2 mm diameter infrared laser beam to temperatures between 900 and 1300 C. All takes place under ultra high vacuum conditions. We use sapphire windows for access of the laser beam and extraction of the light through the top cover 1 mm holes.
We want to measure the temperature of the cup with a pyrometer using the light emitted through the top holes in the steel cover plates If this system were a perfect black body cavity we would use an emissivity on the pyrometer system equal to eps = 1. However, this cavity is not perfect. As said it is open at the bottom for access of the heating laser beam. It looses heat through the radiation shields around the cups vertical dimension. Furthermore the top hole is 1 mm and therefore is a significant heat loss.
We tried extensively to measure the cups temperature under a laser load by mounting a type C thin wire thermocouple. This did not produce accurate results at all due to what we think is annealing of the thermocouple wire, diffusion of Molybdenum into the wire, and oxidation of the wire after venting to atmosphere.
Are there perhaps any suggestions on how to measure the emissivity and thereby temperature of this "imperfect cavity" using a pyrometer.
Thanks for sharing your ideas and thoughts on this.
