Lots of questions.
You should run a dynamic analysis. Model the 10ms pulse duration as a square wave. You’d also need to know the frequency of the forcing function (which is not 1/10ms). Depending on the mass of your foundation, the 74k reaction can increase non-negligibly. Sounds like a 1-DOF situation. The analysis should be fairly easy to run by hand. Grab the Chopra book for a refresher.
I don’t know what an evaporator does, beyond that “it evaporates.” With more knowledge of the equipment, you might decide that a sinusoidal pulse is more appropriate than a square pulse.
You could also make life very complicated and do an actual impact analysis whereby you define a deflection and figure stresses from there. I only suggest this because you used the word “impact,” which I don’t actually think you have.
