ddelaiarro
BLUF: Is it possible to mimic a solar loading environment solely in a temperature chamber and, if so, how?
We have an 6061 Aluminum box with a known heat load inside. It needs to be subjected to a solar load IAW MIL-STD-810G, Method 505.4, Proc I. Essentially, it is a 24-hour exposure cycle with varying ranges of temperature and solid load. Our company has a thermal chamber that we'd like to pretest our units in to make sure we pass qualification testing. We can't create a solar load with our equipment, but what I'd like to do is create a temperature profile that would essentially mimic the total heat load our module will experience during solar load.
I know the following:
- Surface area of the module, A
- Reflectance level for the paint used
- Temperature and Thermal Loading (W/m2) profiles for the 24-hour cycle
What I'd like to do is convert the know Power from the solar load (W/m2 * A) at each temperature interval to a Delta T that I can add to the prescribed ambient temperature to essentially mimic the solar loading in my thermal chamber.
Any suggestions?
Any suggestions?
