IGES (Photorender)
  • Thread starter Thread starter Katia
  • Start date Start date
K
Katia
Guest
I have tryed succesfully the Photorender option to quickly convert in IGES also big assembly. I would like to know if someone could confirm me that the IGES quality (precision,tollerance) is the same of the std IGES export (at the first look it seems good).
Thanks for your help.
Try to explain your question little more
Thanks Speling for your answer/question.
I need iges to use it on a 3D machine for a dymensional check of a built model. I need a lot of iges to be made in a short time, each day, and this Pothorender option effectively made it very easy. I should be sure that geometry is correct.
Katia
Hi
I think that iges is quit enough precise for your needs
