IF THERE IS EASY WAY 1
MORALES68
HI,MY QUESTION IS I HAVE FINISH A DRAWING OF IRREGULAR LOT SHAPE MY BUILDING IS INSIDE THE LOT , THE TIES CHANGE FROM ONE SIDE TO THE OTHER MY QUESTION IS IF THERE IS ANY SIMPLE WAY YOU CAN LOCATED THE SPECIFIC POINTS FOR TIES OF THE BUILDING BECAUSE THE WAY I DID I LOCATED ONE POINT OF THE TIES AND THEN I ROTED THE ALL BUILDING TO MACH THE OTHER TIE POINT IF THERE IS A SIMPLE WAY TO DO IT PLEASE HELP MORALES68
Depends on building shape, lot shape, whether ties are to a specific point or just an offset from a property line.
If ties are to 2 opposite corners, you'll know the distance between the ties (the building's diagonal). Then you could offset the 2 property lines, then draw a circle using the "tangent tangent radius" method; the circle will intersect the offset at the corners.
