if I use cm for length, what should I use for density?
abaqusforum
I don't have lots of experience in dynamic analysis. if I use cm for length in dynamic analysis, what should I use for mass? Youngs modulus is kgf/(cm^2)?
Thanks!
Why would it make any difference, other than the scale of the result? The only concern should be using consistent units throughout any analysis.
TTFN
FAQ731-376
what's the density unit consistent with cm?
I have a model generated by somebody else in cm. those density of steel is about 10^(-5). I want to convert to meters.
okay
density of steel is roughly 7.85(-3) kg/cm3 so in SI it is
7.85x(100 cm/1m)^3=7.85(+3) Kg/m3
whereas in the conv english units
steel density is 0.283 lbf/in3 but in
mass units it is 0.733(-5) lbm/in3 more or less
so it would appear that the originator of your model is using mixed units
Why can't you ask the perpetrator? You haven't exactly given a complete number, yet, you're expecting a cogent answer.
What is the exact number?
the density of low-carbon steel is:
7.87E-6 kg/cm^3
~ 10E-5 kg/cm^3
TTFN
FAQ731-376
I think the first question is what units are "you" working in for your project? SI or English?
Tobalcane
"If you avoid failure, you also avoid success."
Whatever units you use, make sure that the formula F=ma applies.
yup and in english F=(m/gc)a...
Tobalcane
Thanks Denial. The problem has been solved as you suggested!
