IEC - Method of cooling -Nomenclature - help 2
macmckim
89
I am trying to find a web site or documentation that explains IEC - Method of Cooling nomenclature.
I have a inquiry from a client that requires IC616.
Any assistance would be greatly appreciated.
A full desciption of the IEC cooling codes can be found in IEC document 60034-6 . IC 616 translates to what you will know as a TEAAC machine with a separate motor driven fan to circulate the external cooling air , whereas for code IC 611 the external cooling air is circulated by a shaft mounted fan.
