Identifying leads on 12 lead 480 volt 3-Ph motor
eng1
Industrial
Dec 19, 1999
1
I need a good procedure for identifying the leads on a 12 lead 480 volt 3-Ph motor using meters.
If you are looking for good diagrams you should get a copy of the Electrical Engineering Pocket Handbook. This is a pocket sized book that has a lot of handy information including most of the terminal connection diagrams for motors and transformers. This booklet is published by the Electrical Apparatus Service Association (EASA).
