X4vier
- Feb 24, 2018
- 158
I typically refer as connecting Plate, the plate that replaces the inner flange of the members that has the knee on it. In the image below, the rafter, but usually the column.
I'm trying to model that connection plate, using a stiffening plate parallel to the inner flange, and then cut the member with that plate but the cut function doesn't weld the edge of the connecting plate to the edge of the inner flange. Even trying to add the edge-to-edge weld doesn't work.
Any idea how to weld these edges?
