icreasing number of results in workbench 12.1 1
speedmethal
22
hi all
I've the next problem. When I excute solver at workbench I get the error:
Number of results on results file exceeds maximum of 1000. Maximum may be increased with /CONFIG command.
I try solve this by insert command option and write
/config,nres,1500
but it didn't work. I also try insert the first line as
/batch
/config,nres,1500
idem result
does anyone know how do it?
Thanks for everythings
I have seen in the tutorial that the /config command is not valid for the Ansys Multiphysics 1,2 or 3 products. I think that Multiphysics is the license. My question is now:
is there any way to change the license in workbench and therefore introducing the /config command?
I found how to change the license (tools->license preferences).
I set Ansys Mechanical, but when I run Solve, Ansys seems not understand the command /config,nres,1500.
Any idea??please.
Hi!
I've seen a thread like this started by micmaf
"Hi! I have made a transient analysis (full method) with load step 10 sec. and time step 0.002 sec. With "CONFIG, NRES,5000" I get all substeps in the Time HISTORY POSTPROCESSOR (POST26), but I get only the first 800 substeps (up to 1.6 sec.) in the GENERAL POSTPROCESSOR (POST1). Does a command exist for increasing the results in the POST1?
An answer would be a lot of help. Thanks!"
and ansysfread answered
"The default maximum number of substeps in the results file (Jobname.RST) is 1000. When the number of substeps exceeds this limit, you need to issue SET,Lstep,LAST to bring in the 1000th load step. Use /CONFIG to increase the limit.
Garry"
I've tried insert one command in ansys workbench with below two lines
SET,Lstep,LAST
/config,nres,1500
but ansys workbench still doesn't recognize it.
can anyone help me?Thanks
looking solution information i get:
*** WARNING *** CP = 2.543 TIME= 00:23:13
/CONFIG is not a recognized SOLUTION command, abbreviation, or macro.
This command will be ignored.
help me!!!
ansysfreak, you are a genius.
work very well.
Thank you very much.
