Dchris5212
Industrial
I am a foreman at a heat treating plant and I was wondering if anybody can come up with an explanation for a serious situation I ran into a few days back. I was running a can-eng fluidized bed (small load of 8620 steel) 54 lbs divided into two baskets. The baskets sit on a long shaft that we lower into the heating zone full of aluminum oxide and after x amount of time take out and proceed to quench into a very large oil tank (roughly 500 gallons). We have a above oil agitation system (small pump that recycles bottom oil back to top through a hose that sits about 5inches from top of oil). We use AAA quench oil. Upon quenching we had a large flame come up through the quench area which is typically common, though this time the flame proceeded to engulf the entire top layer of the quench tank oil and continuously burn getting stronger and stronger. This has never happened and we have quenched out loads much much larger and heavier. Fire department was called in to resolve. Only thing we keep coming up with is possibly the oil completely broke down though I find that to not be to realistic a situation. Also I think the aggitation system also played a role in feeding the fire. Any help or explanation why this might've happened would be much appreciated.
Thank you
Thank you
