Hi everyone, I have just started a new job as an entry level mech eng working with steam turbines and steam compressors. Today I was asked to verify a proposed design for a two-pieced lifting collar / ring.
I have no clue on where to begin to analyze this and see if it will with stand the 7000lb that it will be lifting...so any help on how you would do the calcs would be greatly appreciated
ok heres the jist of it....it is a two piece collared lifting ring that will be placed around a machined notch on the rotor shaft. (picture a circular donut 1 in thick, 6 inches o.d.) the two pieces when placed around the shaft will be bolted together using a drilled and tapped 1/2 inch hex head bolt....90 degrees to the bolts is two bolted on swivel lifting trunions where the lifting rigging will attach.
I know the fail points will be either at the lifting trunions, or the bolts, prob is its been so long I dont know how to do the calcs for this.
how would you do the calcs to see if this thing is safe to use?
I will attach pics and a shop drawing if needed.
Thanks again
Thanks again
