I may be in the wrong place, excuse
jeannier1975
Computer
Aug 14, 2019
3
I may be in the wrong place, excuse me if I am. I am creating a wonderware application and I need to create some reports. the reports are Emission tags. I enter the start date and end date on excel form and by using historian wonderware formula (= Sheet1!$A$1:$A$10,"Row7",AFStartBinding,AFEndBinding,254,0,0,0,0,3,0,"",3,"",-1,0,"","NoFilter",20480))
I want the user to click on a button and it inputs the emission tags into the next excel row.I have tried something like this (Sub Test1()
Dim strFunc As String
Dim lngLastRow As Long
strFunc = "= Sheet1!$A$17:$A$21,""Row7"",AFStartBinding,AFEndBinding,254,0,0,0,0,3,0,"",3,"""",-1,0,"""",""NoFilter"",20480)"
strFunc = "='strFunc = "SUM(B9:B10)"
Range("A21").Value = "ExtractDate"
Range("A22").Formula = strFunc
lngLastRow = Cells(Rows.Count, 1).End(xlUp).Row
Range("A" & lngLastRow + 1).Value = lngLastRow
Worksheets(1).Calculate
End Sub
Function As Date, dtEnd As Date)
= DateDiff("d", dtStart, dtEnd)
End Function
But when i run the data it enters just the date field and no emission tag values and deletes the formula in all the cells.Any guidance on the issue would be grateful
You never responded to my response in Tek-Tips.
I notice that you also failed to correct one of your function arguments.
Skip,
[glasses]Just traded in my OLD subtlety...
for a NUance![tongue]
i never saw it i do apologize if you can help just help me.
Then please respond to your original thread in Tek-Tips.
Skip,
