Hi all,
I am using SE 19 now, but I've been working with SE since ver 11 and overall I find it is a great, solid tool that leaves almost nothing to be desired. Well, almost...
Wondering if others find the following quirks a nuisance like I do. Feel free to add your own, or workarounds if you have any, which will be useful to all of us.
1. My main beef, and constant pain in the neck, the "Move/Copy" button when moving or copying an item. Don't know if I am the only one, but I constantly forget to check it one way or the other, and always, after an extensive selection process, find it didn't copy, or, it did. Drives me nuts! Would love to see separate "move" and "copy" icon.
2. Lack of a polygon select. OK, I know it is there now, but only with the select tool, and not with the copy/move tool, which adds an extra step to the process.
3. A delete button. Instead of a two click process. To delete a series of lines one has to first select the item, then press the delete key to remove it. Would be great to have a single tool that you simply click on the item and it is gone. This can be done with the trim tool, but it has a nasty habit of trimming, instead of removing the entire entity.
4. An offset line tool that removes the original line. Man, I sure could use a tool that does this. I offset lines often with the type of work I do, and do not need the original line afterward, which means an extra step to go in an delete the line. (See item 3...) I know there are options like coloring the lines and using Smartselect, but that is an extra step that could be eliminated.
5. The lack of a perpendicular relationship when rotating items. This one really sticks in my craw! Try drawing a rectangle on an angle, select it and rotate it perpendicularly to another line. The perpendicular handle will not activate. I have yet to figure out why this option disappeared after ver. 15.
6. Lack of a polygon tool. Why? Don't we all have to draw polygons often? Why is this missing?
Yes, Solid Edge is a great piece of software, but could be much better with a few simple changes.
Anyone else find these issues irritating?
Tim
Tim
