cjoehilton
I have just installed a new Diesel Fuel Supply System for our Diesel Fuel Generators. I more or lest replicated the old system except for the old gear pumps were 1" and I increased to 2". The reason being the new pumps were 2" suction and discharge. I have about 18" from my strains to the pump on the suction side. On the discharge side I have a gauge check valve and ball valve, in that
order.
The problem is when I first start the pumps they make a loud grinding noise. I have checked pump and motor alignment and its alright. I have had the pump rep on-site and they say that the pumps are fine. The one thing that I was concern with is the distance from the discharge to the check valve. I a have not found in recommendations for this distance, I have about 8". As a test I removed the swing arm inside the valve and the noise went away.
What should this distance be?
Thank you
order.
Thank you
