I have a thrust bearing sitting on my bench. To order a new one would take 30 plus weeks, which I can ill afford.
I have decided to approach a few machine shops to quote repair or replacement of the races. But before I do, I want to understand the difference between the Ball Diameters and the Radius they ride in.
The Thrust Bearing is from a Vertical Turret Lathe. The generic size of the bearing is 28" OD x 24" ID x 2 1/2" high.
The Balls in this bearing are 1.0000" Diameter. The radius that the balls ride in is .5400".
What is the rational for having such a big disparity between the radius of the ball and the radius of the ball groove.
Darrell
Darrell
