hydrocyclone using wedge wire screen
pumpmann
NA
have any one made a custom hydrocyclone (cenrifugal action) strainer with a wedge wire screen mounted in a vertical tube with a back wash at the bottom. the application is for installation after pump station of irrigation system ? or anything similar that you are aware off?
A sketch may improve our understanding.
Good luck,
Latexman
I've made hydrocyclones, out of sheet metal, not screen.
From a fluid standpoint, they work sort of like a pump in reverse, with one important difference; there are three flows. The dirty bleed flow out of the bottom center of the cone must be continuous.
If you want to dump that concentrated effluent into a bucket and periodically wash it away, that's an option, but it's more common to just pipe it to where you need it. (Or in filtration applications, use it as the input/motive flow to a cascaded section of fewer or smaller cyclones.)
Mike Halloran
Pembroke Pines, FL, USA
thks
Mike, what is the typical screening size achieved with your hydrocyclone?
Are you using a V shape (funnel shape) cylinder?
