Hydrocad is a great program and I use it every day. However, I wonder why the minimum dt is 0.01 hr. For many projects I see, this means that simultaneous routing will not work because oscillations almost always occur. I would like to see a minimum dt of 1 second like PCSWMM and this would make it an even more useful tool.
Also, at least one recent paper dealt with values of Ia/S and the authors claim that the ratio should be 0.05 instead of 0.2. I haven't found a way to change the ratio in Hydrocad. Is this possible, and if not, why not?
