UG -99 of ASME SEC. VIII DIV 1 asks to consider lowest stress ratio while calculating hydro pressure.
NB- 6220 does not specify requirement to consider lowest stress ratio while calculating hydro pressure.
What is the rationale behind the difference in requirement of the two codes?
Is it that due to higher factor of safety, higher hydro pressure is permitted on SEC. VIII DIV 1 equipment?
