Question for hydro engineers:
I am working with a client who has recently installed new voltage regulators on some old hydro generators. The exciters are rotating dc generators. As part of this retro-fit, they apparently removed old existing field breakers and some field discharge resistors.
They have been experiencing, it appears, high voltages at the generator main terminals after a unit trip (turbine will run up to probably 150 - 175% speed for a while, typical of most hydro units).
Assuming the new voltage regulator is properly shutting down on a generator trip, would there be enough residual flux in the exciter to create dc current sufficient to cause overvoltage in the unloaded ac generator during this overspeed condition?
