Speedy
- Jun 5, 2001
- 229
Could somebody please explain the following Hydraulic Schematic?
There are 2 pumps. The left is simply for the heat exchanger. The main pump (on the right), I understand to be of constant speed with the pressure regulated by a proportional valve.
However the schematic would seem to indicate that the pump is variable displacement (symbol-slanted arrow across pump) with a mechanical feedback on pressure.
What does the 'P' represent? I assume it is pressure.
The max pressure is 300Bar with over-pressure protection from a relief valve on the supply side.
Any comments welcome.
Speedy
Speedy
