We have built a jig to test hydraulic jacks. Under extend, we put the jack under 2400psi pressure. The pump is turned off and the pressure drops to 2000psi. We lose a little hydraulic fluid.
When we retract the jack, we pump to 1200psi. When turned off the pressure remains at 1200psi.
Is the jack damaged? Is it the internal seal that may have dirt or rust that causes it not to seat properly when extending?
Any advice is appreciated.
