Being moved out of my material comfort zone and into fluids after a job change; and in need of some basic advice.
we have a pneumatic driven oil unit that can develop 700b and a flow rate of 5.3cc/stroke. The cylinder that is being supplies is a double acting design 2" bore and 1" rod dia, to open a 660lb vessel lid and the cylinder is rated to to 200b.
In an effort to reduce the stroke time the supply pressure was allowed to run to maximum - even I know that pressure dies not give speed !
But the question, if the pump is design to give an output of 700b - will the system see that pressure or will only see the the pressure generated by the resistance due to the load ?
many thanks
tony
many thanks
tony
