hydraulic breaker repair
PaoloB
7
I'm repairing a hydraulic breaker, upon stripping found light scratches in the piston rod and housing (sleeve).
Planning to repair the rod by machining the scratches and have it hard chromed.
Is there any info regarding the allowable clearance between the rod and sleeve?
I'm just worried the new clearance due to machining might affect the performance of the breaker when oil heats up.
Aim for 0.008mm radial clearance.
Equation for leakage is
Q = [πR (R-r₀)3/ (6 µ L )] (1+ 3/2ε²) ∆p
where ε =e/ (R-r₀)
R is bore radius
rois spool radius
μ is oil viscosity
L is sealing length
Δp is pressure drop
e is eccentricity
where ε =e/ (R-r₀)
R is bore radius
rois spool radius
μ is oil viscosity
L is sealing length
Δp is pressure drop
e is eccentricity
Thank you very much.
I wonder, is above equation can be found in the CFD subjects?
Possibly
A derivative can be found on Wikipedia.
I’ve used it in 1D simulations like Amesim and Matlab.
