While either program allows you to use the Rational Method and combine hydrographs, you may not want to use them that way. The Rational method does not generate a realistic hydrograph and is considered valid, if at all, only for small, urban watersheds. I, and my local City, limit its use to 20 acres or less. I use the so called modified Rational Method only if require to by some reviewing agency. Even then, for any really important project I would check the results by at least two other methods such as TR-55, Santa Barbara Urban Hydrograph, or Regression Equations. Tiny parking lot and similar "local" detention basins do not fit the description of "important".
good luck
