HVDC model - CDCAB1
wowski
AU
I am trying to track down the description of a HVDC PSSE model, known as CDCAB1. Unfortunately the psse manual is a bit lacking in the description. Does anybody know where I may be able to obtain this information from- it must be out there somewhere.
Section 17.10 of P.A.G vol 2 in the PSSE manuals seems to have a fairly full description - what exactly are you looking for ?
The psse manual is only an excerpt from the model description. I am looking for a more full description of states and how to perform certain tests on the model.Eg. cable faults etc.
As a last resort ShawPTI may let you have a copy of the source code for the model - if its the actual workings of the model you need to investigate and seeing the Fortran would give you the info you need.
Suggestion: It may be a good idea to seek references the PSSE Manual is based on.
