HVAC Design and/or Load Calculation
montoy
29
I wanted to know if do you need to be a P.E. to design HVAC or do a load calculation? Or does your work or design needs to be stamped by a P.E.? I work for a Mechanical Contractor but we have no P.E. employee.
Thanks.
it depends on the state regulations. Here in WI a PE is required when the building is larger than 50,000 ft³ in volume. I know in other states it is more lax, but in some states it might be more stringent. In addition your municipality can have additional requirements. should sk the local building inspection.
Here in CA, there is a license you can obtain so you don't need a PE stamp to design light commercial buildings (i.e. retail stores, small offices). I asked the same question at my old workplace where all the engineers were interns.
