Dear all, Good afternoon !
We are working over outlet of Super heater Gate valve (12" X 10" X 12" X 2500# BW)on superheated steam line
(12", Des.Pressure 130 Kg/ Cm2, Temp.: 540°C ) this valve having equalizing line (1")with 1" Globe valve.
(Line is from Valve body to Valve body), My question is as follows:
1) What should be the type of welding joint for equalizing line 1" to Globe valve 1"x 2500 # - SW or BW?
2) Should we follow 12" main line specification for above weld joint? if not then..
3) Does any separate spec. for such Equalizing/ balancing line? if yes which one.
With Regards
With Regards
