Dec 26, 2003 #1 sgms Chemical Joined Nov 23, 2003 Messages 13 Location QA We experience with leakage on gasket for HP Steam (115 barG). Does any body know what suitable for this application. We have tried kligrite (wit wire) and graphite but not sucesfull
Dec 26, 2003 #2 tothepoint Mechanical Joined Mar 31, 2003 Messages 91 Location US What type of flanges do you have? Are you sealing the turbine casing or the inlet piping flanges? Upvote 0 Downvote
Dec 29, 2003 Thread starter #3 sgms Chemical Joined Nov 23, 2003 Messages 13 Location QA We seal level gage that connected to steam drum (saturated high pressure steam) Upvote 0 Downvote
Jan 4, 2004 #4 smckennz Mechanical Joined Feb 25, 2003 Messages 208 Location NZ look at spiral wound gaskets. talk to your local supplier. They require careful handling and possibly flange refacing. But they will work. Cheers Steve McKenzie Upvote 0 Downvote
Jan 13, 2004 #5 PAN Mechanical Joined Apr 25, 2001 Messages 549 Location SG For HP steam at 115 BarG, flange should be Class 900 or 1500. Spiral wound gasket may not the good choice. I suggest to use ring joint gasket. Repeat the question from tothepoint. What type of flanges do you have? Upvote 0 Downvote
