How to turn off wire harness centerline display in 2D drawing view
zydee
DE
Does anyone know how to turn off the centerline display when you place a assembly view containing wire harness?
Thanks for your help
RMB over view and select Properties. Select item in the list on the Display tab that has Tube centerlines. Right click over item and select "List Centerlines". Then click on the centerline and un-highlight "Show". Then update the view.
I wrote a VB6 program that will iterate through each view on the Active Sheet and hide all centerlines. I can send you this program if you would like.
