Hi all,
I have to select several microswitches of single pole double throw type for our control lever box. The switches I could get from my supplier has seperated inductive and resistive current maximum, the switch1 has 1A resistive and 0.5A inductive gold contact and switch2 has 7A res/4A ind gold overlayed silver contact.
Six switches will be used in the box and two of them will be switched to loads like solenoid and valve(inductive?)with 28VDC, and the other ones used as ground/open switch(discrete status to microprocessor).
So what I am a little confused is why are two kind of current given, from my understanding it´s no difference whether a resistive load or a inductive load flow through the switch? I only need to know the overall maximum current from the both, am I correct?
Another point is what is the difference between the two kind of switche contact? gold overlay sounds not so good under high voltage test e.g. 80V for 100ms.
Thanks!
Thanks!
