You work with the motor suppliers to find a motor that is the most efficient at the load you are applying to the shaft. In this case, a 150kW motor that is the most efficient. Am I missing something?
Burnt2x - I'm not sure I understand why you'd divide the required motor output power by the motor efficiency. The motor rating is the output power on the shaft. The input power to the motor includes the motor efficiency.
