How to read "Means this"?
SeasonLee
TW
Hi All
Please ref to Fig. 12-2 of Y14.5-2018 as shown below
I have a question at "Means this", how can a 0.2 tolerance floating within a 0.03 tolerance zone? Please let me know if anything I missed here. Thanks for your help.
Season
There is no use specifying datum reference B; no idea why that was seen as required; a plus-minus directly toleranced dimension would serve just as well. And it doesn't affect the sloped surface feature control frame at all.
Both specify datum reference A, which makes centers meaningless to verifying the requirement.
It still suffers the flaw that the much larger runout tolerance range is shown as much smaller than the size tolerance. It's sloppy work that misrepresents the situation and, by showing nearly no runout on the tapered version, when the runout is much larger than the size tolerance, is worse.
@3DDave
in gear & grind shops use manufacturing equipment that utilizes centers.
and inspection equipment that utilizes centers, it is essential to allow manufactures to use centers.
these are parts that have tight and less than .0005 in size and total runout requirements for
bearing journals , and or gear and spline requirements for tight Pitch Diameter Runout.
basically shafts with tight engineering requirements.
it makes grinding outside diameters and gears simpler.
if the case of "mean this " It would be optional centers for clearly that example part of no heat treat
requirement it could be easily turned to the specified requirements.
I trying in vain to communicate what if situation.
My understanding is: A single cylindrical feature can be used to establish an axis when it is long enough to orient the part, if the cylindrical feature is not long enough(as shown on this case) to orient the part, then we need a secondary datum feature to orient/locate the part, so in this way we will have a repeatable datum axis in measurement.
This is where I still can't image how the runout will effect the form in this case.
Season
They cannot compete to see which is more orientation-controlling. If datum feature A is too small to control orientation then datum feature B should be primary.
As to the second part - me neither. It's not what I wrote, so is this agreement??
|A-B| would probably make more sense as a solution to the repeatability/stability issue than |A|B|.
agreed,
no mater what the requirement of .02 runout has to be held, the mfg is therefore forced to hold tighter form requirements of the 19.13 diameter.
because otherwise it will not hold the engineering requirement. and this is often done.
the diameter can be between tolerance of the diameter with form that maintains the runout.
Burunduk,
What do you imagine |A-B| looks like? Ie: while contacting B where does the contraction for A stop?
The contraction on A will stop on datum feature A.
Rotational degrees of freedom will be constrained by A and B together if A alone is unable to constrain them properly. It will be simulated the same way as in the original version but the |A-B| specification may represent what happens better. B as secondary doesn't constrain any meaningful DOF for runout on the cylindrical feature.
I agree that as currently shown "B" brings nothing to the callout. If "B" is primary than I see some value added concept.
I think A-B is a valid approach in ISO GPS, but no so much in ASME.
In ASME I've never seen this A-B in any on their drawings (A and B in depicted scheme)
greenimi,
For a scheme to be valid it is not required that an example duplicating the exact case is shown in the figures.
The text supports it.
From the 2009 standard:
"4.12 MULTIPLE DATUM FEATURES
Where more than one datum feature is used to establish a datum feature simulator for a single datum, the appropriate datum feature reference letters and associated
modifiers, separated by a dash, are entered in one compartment of the feature control frame."
The datum axis will be derived from a simulator constructed by a component with a planar face for datum feature B to be supported against and another component with a contracting chuck the axis of which is normal to the planar face. Datum |A-B| is an axis and a plane at a right angle to it. We know that a "single datum" is not always only an axis or only a plane, because there are datum features that establish a combination of plane+axis or plane+axis+point, as indicated by the table in fig. 4-3. The combination of axis+plane I described will be established by the simulator of datum feature |A-B|.
Let me know if you still think it's invalid, and why.
Definitely I would say this in uncharted territory for ASME. I do not think this is the way Y14.5 committee envision usage of common datum feature primary A-B.
Even in ISO GPS the way to use A-B in this context is not very common and there are ISO users/ experts uncomfortable with the interpretation.
As far as I know, the intended use of a common datum feature/multiple datum feature is to have 2 features or more labeled with datum feature symbols of different letters constraining the same degrees of freedom together without precedence of one over the other. I can't see how this case is outside of the concept. The only drawback is lack of an example/figure but as I mentioned what matters is that it can be interpreted per the paragraphs. Other than ISO experts' opinions, are there any specific ambiguities you recognize when the scheme is interpreted per ASME? What part of it may make the drawing user who works per the standard stumped?
