I have a small servo motor that the shaft is only 0.25 in in diameter. The peak Torque of the motor is 90 oz-in (0.64 N-m), or continous torque is 38 oz-in (0.27 N-m). The no load speed is 7820 RPM. While we have the drive sprocket in which the drive shaft has the maximum length of about 3/4" and diameter of 28mm to fit. How can I use that motor to drive that linear guide? It seems like a huge difference between 2. Thank you.
w.k.
w.k.
