I need to produce such a response to a load:
an constant acceleration of 0.5m/s^2 for 1/100 of a second.
The initial velocity is not important. What matters is that during that 1/100 second time interval, the acceleration is 0.5 m/s^2
I thought about using a cam to produce this response. Basically, a parabolic camshaft.
The problem is, such a cam would be very hard to machine, because the lobe would be practically non existant.
the distance traveled would be (1/2)(acceleration)(time)^2, which would be (1/2)(0.5m/s^2)(1/100 sec)^2 = 1/40 mm (0.025mm). This is very small distance so a cam lobe is hard to manufacture.
My idea is to use a gear train via rack, pinions, and gears. I will "amplify" the acceleration by a factor or 25 at the cam lobe (so the parobolic lobe is steeper), and then "bring it" down via a gear reduction.
I wonder if this is a way to do it? Please help. Thanks. I'd like to hear your feedback and opinions. This is an interesting and very important (to me) application.
