NorthwesternDesign
Automotive
Attached is an image of my drawing of an eccentric shaft. I don't think what I have is correct. There are bearings on each of the datums that I have called out (except the keyway of course "G"). The keyway is strictly driving the shaft and its location is probably not critical, but I used it as a datum to orient the shaft diameters in line with it (see the end view, as all the shafts are on the same centerline). I don't think I can call out the centerlines as datums either. I also don't think my runout conditions are called out correctly either. Any help would be appreciated!
