drennon236
Inside the cylinder all the values (red arrows) are positive, while outside all the values (blue arrows) are negative. I only want the positive values, when I try to extract I get both positive and negative. How can I only get positive values?
I can only get the output I want through position: Element nodal, so I cant for example make a set containing nodes only on the inside as the output I want is not given for individual nodes but only whole elements.
