how to move data from an array into a element table?
Fernandox
Materials
ES
With this:
/POST1
set,last
etable,melted,temp
esel,s,etab,melted,875
/SOLU
*get,longitud,ELEM,0,count
*DIM,tes,ARRAY,longitud,1,1, , ,
*VGET,tes,ELEM,longitud,elist
I have the selected element (elements with temp>875) id numbers in an array (named tes). I need to transfer that information to a table to be used later with esel to reselect again those elements. I will not be able to used the same method because the temperatures of those elements will have changed.
I think it can be done with *vput, but I am not able to get it right. Any help, please?
I think that the easiest way for this puspose is to define a component:
cm,NAME,elem
cmsel,s,NAME
hey, thank you very much.
I will try it.
