Currently I am working with a unique actuator which under the simplest explanation is like a small rope which we can control the contraction of. This actuator can easily be cast in flexible polymers and then used to control the shape/motion of the cast structure. In the past the FE models have simply used forces applied at each attachment point of the actuator. This is no longer really a valid solution due to the longer lengths used and the large deflections needed.
The model can basically be thought of as cylinder approximately the size of a finger with a line element running top and bottom along the axis at the surface. These line elements will represent the contracting actuators. As they contract(strain) the cylinder would bend similar to a finger curling.
I would like to be able to control the strain of the actuators directly in the model. One method I have considered is to model the line elements as truss elements with a material with a thermal expansion constant. Change the temperature of the model and that would control the actuation. Then I would later be able to relate the Abaqus temperature to the fluid pressure that we actually use to control the actuators. The issue with this approach is the actual resulting strain of the actuator is also dependent on its modulus of elasticity. If the modulus were infinite the change in temperature would directly control strain, but of course the whole infinite modulus is an issue. I will also need to know the overall force the actuator needs to maintain that strain level. Note the actuators have no appreciable bending stiffness, so modeling them with 2 force members like trusses should be sufficient.
I realize the problem is a little unorthodox. Is there another element type I could couple with a state variable like temperature/charge/etc. to get this kind of control of a line element?
Thanks,
EBD
Thanks,
EBD
