Moisture content in saturated steam is notoriously hard to measure reliabily in the power plant. To give you an idea of the extremes needed to measure it accurately, nuclear steam supplies (most of which are saturated) are sometimes tested by injecting radioactive tracers in the feedwater before the steam generator. It is assumed that the tracers are carried over only in the water droplets so the percentage residual radioactivity is assumed to be equal to the percent moisture in the steam supply out of the steam generator. Believe me, this type of test is an example of a test you DON'T want to do. You cannot imagine the bureaucratical mess needed to do this test. Even in nuclear plants, this measurement is done once or twice in it’s life time.
