I'm guessing this isn't going to be possible...
I'm using a triangle pattern within a boundary, and I need for the pitch
to increase with each instance. So the pitch needs to grow from the center
of the pattern outwards. I work with rubber molds, and the reason for this is
to accommodate matching up to a hot mold that has thermal expansion. For instance,
the pitch may be a static 1" when it's cold, but 1"x% when it's hot.The % growth is
based on the distance from the instance to the center of pattern. Hopefully that
makes sense.
nx 8.5
thanks!
makes sense.
nx 8.5
thanks!
