How to let .Sdb file which is saved in sap2000 ver. 14 also be run in sap2000 ver. 11
jachou
TW
Hi,all
I create the .sdb model in sap2000 ver.14 which just contains line frame object ,but for some reason the .sdb file must be run in sap2000 ver 11. Is there any tip to convert ver. 14 sdb file to ver 11 one?
Thanks!
You could try to change the version number inside the $2k text file and import it into SAP2000 version 11. Sometimes it works when the version numbers aren't much different, but I can't be sure if it will work in this case.
Thanks for your respose ! I have already previously try your way ,but errors still occur .
