1.) Select an other op.amp
2.) add a buffer (bipolar, FET, buffer amplifier, etc.)
3.) if a load is asymetrical, add a pull-up or down R.
4.) Use higher power supply voltage
5.) Add heat sink
Generally the best way depends on what do you have and
what do you want i.e. specipications, requirements and means
including urgency, quantity, cost, maturity of design,
experience of the designer, -- level of confidence--
reliability, -- MTBF, -- etc. etc...
The best way to get help is to describe exactly what
do you need -- with data.
<nbucska@pcperipherals.com>
