I have a pump requirement for 60 gpm @ 1300 psig and I want to know what type of pump to use and which manufacturer has suitable selection for this application. Thanks
A couple of choices would be PD (piston type pump) or a high speed centrifugal like Sundyne.
Efficiency on the Sundyne will be a lot lower than the PD but you'll have the ability to modulate flow directly by throttling the pump discharge where the PD would need a recirculation loop.
There are a lot of other people much more experienced in this than I am, will be interesting to see if I'm close .
What are you pumpin?? What is the liquid temperature & properties ???
At 1300 psid, you are into a small multi-stage centrifugal pump design...... kind of like a small boiler feed pump for a 30,000 lb/hr boiler
Try Goulds pump......they offer the model 3935 which is a horizontal axis, multi stage centrifugal unit. Also look at the multi-staged (radial split) ring pump.... the model 3310.
I believe Ingersol-Dresser pump (now owned by FLOWSERVE) has a similar models...... try
To spec a pump capable of delivering 60gpm against a back pressure of 1300 psi, you need to decide which route to go down, If it has no particulate and an SG similar to water then a multistage centrifugal pump is suitable as long as you have enough space to fit a motor the size of your house, if there is a small amount of particulate or a higher viscosity, a high pressure diaphragm pump like the Wanner Hydracell would be preferred, if the flow needs to be variable or you require a more energy efficient option then a Piston/Plunger Pump would be my pump of choice.
Hope this helps
