We do high speed punching, each run our dies has punched 250 000 times, but for reason that we couldn't found out yet, some die, make only 20 000 parts and others do 500 000 parts before taking them off for grinding.
We evaluate if or not the die need to be replaced by the quality of the cut on parts.
I suspect that our problems come from grinding. Each time we remove up to 0.010" by step of 0.002" and we do final step at 0.0002".
We use coolant, grinding wheel is sharpened each time we grind the die. It takes 20 minutes to get the die like new. Material is D2 at 62HRC.
We take care of not burning the surface of the die when we grind to keep the hardness high. Often, the first 2 or 3 grinding cycles, we do not have good results but further in the the life of the die, we obtain better results and for the 2 or 3 lasts grindings, we start again having the same problem.
I'll welcome any recommandations that can help us to get more parts between each grinding.
Is there any way, we can get D2 harder than 62HRC. Maybe an other matherial should be use instead of D2??
petecul
petecul
