davidbeach
I have a spreadsheet where certain cells have been given multiple names. Is there a way of easily showing all the names that refer to a given cell?
In this instance, the spreadsheet deals with relay settings, and for instance zone 1 phase mho distance reach may be named Z1_, Z1P, M1P, and perhaps others. This is to facilitate macros that can then use the setting as named for that particular relay. I can see the name that comes first alphabetically in the box at the left end of the formula bar, but is there an easy way to see all the names?
At this point I use ^G (go to) to test to see if a name relates to the cell I think it might. The Insert|Name|Define method is very cumbersome given that there are probably already 1000+ named ranges and many are mind numbingly similar (great for macros, really bad for skimming through lists), and it is sorted by range name, not by cell.
