Attached is a GRIP program which will allow you to select up to 1,000 points in a file and then write the X,Y,Z coordinates to a text file using a 'comma-delimted' format which will make it easy to import into an Excel spreadsheet.
After downloading the file, edit the file extension, changing '.zipper' to '.zip' and then extract the files. I've included both the source and executable. If you open the source file (.grs) there will be instructions on how to use the program in the program description area.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA Siemens PLM: UG/NX Museum:
